(assuming having a stable amp that’s rated 2x at 4ohm vs. 8ohm)
What do you guys see as the +’s and –‘s to selecting 8 or 4 ohm woofer, for example in building a two-way, 2nd order LR speaker?
Regarding the woofer low-pass filter going from 8 to 4 ohms doubles the cap and cuts in half the inductor, so is there a sound preference to selecting either set of components (ultimately to consider in driving the woofer selection?)
Regarding the amp, even if rated stable at 4 ohms (and less) is it more advantageous to go with the 8ohm woofer? i.e. run cooler, less distortion, less stress either way?
thanks
I was also wondering/thinking say if caps (or inductors?) cause more sound issues/distortion than inductors (or is it visa-versa caps worse than inductors?) then, do smaller caps (values) cause less issues than larger values? (Given the same quality of cap). If so, that may be an additional reason to go for 8ohm woofer?
The drivers are always going to be the biggest contributor to distortion.
See section 4.3 in the link for his rationale.
so, Q: does size matter (sorry 'bout that) i.e. does it follow that using a smaller value inductor (by selecting to go with a 4ohm woofer vs 8ohm) cause less problems? or stated differently; is there a sonic advantage to using less of a bad thing?
I’ve heard amplifier damping factor is higher into higher impedance.
Lower impedance allows smaller inductors making large gauge air core inductors more obtainable instead of needing to resort potentially to a ferrous core which may saturate/distort.
These are pros for both high and low impedances. Thoughts?
"In reality, there will be little difference. Although the inductance is smaller for a 4 ohm woofer, the wire has to be thicker because of higher current...
Air cored inductors are at least linear, and their self-capacitance is usually small enough that there isn't much effect at audio frequencies... Resistance is more of a problem, as that causes losses across the full frequency range...
Everything is a compromise, but using an active crossover means that you don't need to use inductors at all (but you do need two amplifiers)."
