Hi Guys,
I'm finishing up my last project for PE, and I have an impedance question for all. Please take a look at this impedance curve and tell me if I'll run into any trouble with amp clipping. The crossover points are about what I envisioned them to be, the phase tracking is great, and the overall FR is flat within 2.5dB. Third order electrical on the woof and tweet, 2nd on the mid. The lowest point is 2.6R at 1,200Hz. Thanks everyone.
If it was at +/-10deg or less I would chalk it up as tough, but not a deal breaker... But at -30, its pretty heavy.
I would not see a 4 ohm stable having trouble, but recievers and chip amps may get grumpy. You will still draw a fair amount of current at 2.6R at moderate or higher volumes alone if the load was purly resistive, but its fairly reactive. Make sure you use a high wattage resistor on that mid.
In short. Not ideal, but do-able. Expect heat. IMHO.
