So, i tried taking a FR measurement today... quite a few things are different - i have a new laptop and hence a new install of Holm Impulse - needless to say i don't have any of the settings. So between struggling with the settings and the usb mic and speakers and amp... half the time the sound was playing from the laptop speakers, the mic on the laptop was trying to measure...
so after all that i think i got the the speaker drivers to play and the usb mic to capture (i think) and then I get this FR. All three are the same drivers, but i spaced them out to make it easier to see.
The first impulse seems to support gating at 300, but i get the weird dips which seems to go away at higher or lower gating and the FR itself looks wonky quite a bit of a rise from 600Hz all the way to 12khz.
But i am still wondering if my settings are wrong or something off with the mic / amp / etc....
I am going to retry again over later... I still didn't hook up the tweeter, would after I figure this out. I also want to try measuring one of my existing speakers. I don't have the old laptop, and i don't trust this setup yet...
this is today's results.... the top end represents the peak/breakup i was expecting (5k -10k+), but the mid/upper bass is still off i guess... now there is no bass the 5k to 7k and lower is supposed to be way more flat than this slope
And computers were supposed to make our lives easier!
Charlie Laub wrote a super easy tutorial to get started. If you need it, I have it somewhere on my computer.
today morning, used one of the el cheapo usb audio dongle which are typically used with phones, nothing fancy, just a basic DAC and measured the penguins.
That's not too bad... the sweep sounded as it measured...
Nice curves... cross around 3k and should be good right?
here's the complete picture... guess what happened!
so inverting it the measurement looks like this.... But now, why does the top end goes whacky??? it's outside the usable range... See the red curve, from 4k - 20k - what's happening here?
Charlie_Laub-FR measurement using ARTA-sept-2012-update.pdf
