.75 cube bookshelf cabinets
Built these for my MarkK RS22528As, you'll be hard pressed to find a more bulletproof cabinet. Laminated 1/2" mdf to make 1" panels and bracing. Bracing full interlock and dadoed, recessed and angled binding posts, 2" OC703 damping. Cabinets are coated in resin, never got to a finish.
Build log on PETT.
http://techtalk.parts-express.com/forum/tech-talk-forum/40265-markk-s-rs22528a-as-surrounds-build-thread
Price: Whatever they are worth to you +shipping. Cabs probably weigh 20ish lbs each.
  • What are the cutout/recess dimensions?
  • edited May 2020
    I can measure for you Dan but they fit the rs225 and 28a perfectly.  If you would like the baffle cut off I could do that too.....
    I can get you measurements Saturday morning....
  • No need to measure.  I'm considering them to use with the Wavecor WF223s which seem to have the exact same flange diameter as the RS225 and the box volume is perfect.  Let me think about it.
