This is the way things go. Back before the virus, I hit every yardsale possible in search of records and a decent turntable. Nothing but cheap junk so I finally gave up and ordered a used Dual 1237 off ebay since they have a good reputation, German build quality, and it met the budget. A week later while casually thumbing through facebook marketplace, I came across a local with another Dual for sale. Well $hit, cannot pass this up. As luck would have it, he had two Duals, a 1237 and 1257. The 1257 was an absolute cherry. Needless to say, even when cherry, some parts (stuerpimple) need replaced and old hard grease needs cleaned out and replaced with fresh. And now there is plenty of time ...
Now I have two TT's up and running with the first ebay 1237 still DIW. It's going to require some digging, and maybe a hammer.
The needles are questionable and most of my vinyl older than these 40+ year old TT's, so there is a new AT85ep and Ortofon super om20 waiting to be mounted.
Have any TT experts in the audience that could guide me in the setup of cartridges? The vinyl is too precious to chance damaging and the needles are definitely not cheap either.
The main things you need to adjust are the stylus tracking weight and the 'anti-skate'. The stylus tracking weight should be indicated in the documentation for your cartridge, and you need a stylus tracking weight measuring thingy. This can be mechanical or electronic, with the mechanical ones being far cheaper: I use a mechanical one I got with a Connoisseur turntable about 40 years ago. You rest the stylus on the gauge and it tells you the tracking weight, which you then adjust with the counterweight or other mechanism on the tone-arm.
There will probably be an acceptable range of weights specified, I suggest using the heaviest if you have a few warped discs.
'Anti-skate' is fitted to most turntables and the turntable manual should tell you how to adjust it. As I understand it, this feature counter-acts the tendency of the tone-arm to skid towards the centre of the turntable, which puts undue pressure on the inner edge of the LP groove. On my Pioneer turntable, the stylus tracking weight for the Ortofon moving coil cartridge is 2.5 grams and the manual advised to set the anti-skate at 2.5 also. The higher the tracking weight, the higher the anti-skate setting - at least, I think that's what it said. Other turntables will have different ways to adjust this setting.
As for mounting the cartridge in the head-shell, I've always used the very front position - assuming you can slide the cartridge around in the slots for the mounting screws - but have no basis for that other than an alleged sales person's advice.
HTH
Vinyl TV
