I would like to make 2: 6.3-0-6.3 transformers into 1:12.6-01-2.6 transformer. Will this work? Pic one is the power supply as I got it. Pic two is the power supply I want to make.
What you show above will short the secondaries of your transformers. Much smoke will be released!
In this case, you won't use the blue center taps at all, so just clip those off and/or insulate them. Take the two inside yellow wires to the "0" terminal and you should be good.
Thanks!!
