Hey gang! Considering stereo work in my bimmer, tweeters in sails, 4" in door card, 9" under the front seat. I will have amplification and DSP. Do you think this would be a solid front stage? I have an Aura MR.18 IB for substage.
Woofer - https://www.madisoundspeakerstore.com/approx-8-woofers/morel-caw938-9-woofer/
Thanks for any thoughts and recommendations.
The 10f has a very (VERY) neutral sound fwiw. You may consider the tc9 for a fraction of the price and a richer (sorry for the subjective word) sound.
No, it's appreciated and will be considered.
This guy?
https://www.madisoundspeakerstore.com/approx-3-fullrange/vifa-tc9fd18-08-3.5-full-range/
That’s the one. Personal opinion only; I have used both. TC9 was a better deal when it was $12.50, but still an overachiever in my book. There are better things out there I’m sure but I’d choose it over the 10f.
Well heck, that's a killer price for a wonderful mid. Appreciate the rec'!
+1 on the TC9. It's crazy good for the money and no slouch at any price.
Done deal.
Where would you guys recommend crossing over the TC9 to the Morel 9”?
~500.
Of course a vehicle cabin is a whole different animal than a living room, but the 9” under a seat transitioning to a 3” in the door could be tricky. You will have to play around with it; my thought is 250-500ish, 250ish needing a steep filter. You will also probably have to play with the mid and maybe tweeter polarity.
The benefit of a car (active) setup is electronic crossover and dsp/eq.
What dynamo said. I'd be more inclined to go back to a 4" mid, something that'll be a bit better down low to blend with the underseat woofer.
I crossed the TC9 at 300 in the Hafnium and didn't have any issues with that. I agree that anything much lower than that would require a steep filter.
Sounds almost perfect then if i am to cross the 9” around 150-200 to match up and not be located?
