You can take care of it with a passive notch filter in parallel with the driver.
You can take care of it with a passive notch filter in series with the driver input. This has added advantage is that it will also suppress the harmonic distortion components marked in blue and purple below-
This has been done for many years but recently documented by Lars@Purifi
DATS V3 data for two current production RS52AN-8 mid domes after 48 hours of break-in at 325 Hz attached at link below - link good until 1-20-24 for those interested.
They [RS52AN-8] sound hissy & dull compared to the HiVi DMB-A's even when employing PEQ & killing all freq's above 4KHz and using steep XO slopes, so DSP cannot fix the SQ and it appears to be a resonance problem. [lending credence to Wolf's prior admonition(s) concerning resonance damping with passive components].
If they are relatively new, I certainly hope they will.
Actually, even if they aren’t new, It certainly doesn’t meet the advertised claims (spec sheet)
Return request sent to PE this afternoon with a link to this ^ thread.
Purchased 2 months ago and only got around to testing them last week.
I was hoping that the RS52AN-8's low Fs and metal domes would outshine the HiVi DMB-A's sufficiently to make me use them with the Fountek NeoCd3.5H Horn ribbon tweeters but, alas - it was not meant to be metal on metal . . .
If you’re talking about the peak above shown here:
Reference:
https://hificompass.com/en/speakers/measurements/dayton-audio/dayton-audio-rs52an-8
You can take care of it with DSP.
Reference:
https://purifi-audio.com/blog/app-notes-2/low-distortion-filter-for-ptt6-5x04-naa-11
"The RS52ANs sound considerably cleaner and more open when suppressing the top end breakup, even if its well outside the passband after the crossover"
From post #249 --> https://www.diyaudio.com/community/threads/the-dome-midrange-thread.407105/page-13#post-7565435
DSP won't fix that . . .
https://we.tl/t-LilFJ8IANw
Hi Steve,
I can’t seem to access those files.
Do you mind posting screenshots of what you see in DATS?
Please show a zoomed impedance trace, eg. Y axis of 10 ohms.
Windows Key-Shift-S to do screenshot.
Thanks for checking-in, Thanh.
Z data in .txt export:
Fumbling around with on line calculator using opposite notch filter terminology
Hmmm.
The impedance plot suggests that there are two resonances:
This seems to similar to the one detected around 2020:
With this frequency response:
Please read this post; accounting for difference between the early production run circa 2008:
https://www.htguide.com/forum/forum/primetime-a-v/mission-possible-diy/driver-testing-discussion/32744-driver-evaluations-for-a-new-project?p=833366#post833366
And this post; documenting the change:
https://www.htguide.com/forum/forum/primetime-a-v/mission-possible-diy/driver-testing-discussion/32744-driver-evaluations-for-a-new-project?p=833367#post833367
This certainly complicates the issue…
PE never addressed that issue, either. Not to my knowledge, anyways. Pity - those mids have so much potential.
Steve, that is a parallel notch, as the parts are all in parallel with each other.
I think I will see if I can send them back to PE for a refund and get some other domes instead.
Life is too short to waste on broken toys . . .
Thanh - thanks again - you are consistently helpful and educational.
Steve,
PE takes anything back.
Hear anything back from them?
Got bounced around for a bit but they issued a Return authorization this morning and will send a return shipping label shortly.
Thanks for asking, JR.
