I'm using some surplus Dale aluminum power resistors in my crossovers. I know they have some inductance and my budget LCR meter says it's on the order of 0.11mH. I'm questioning the accuracy of that measurement, but the data sheets are no help on this issue. The question is - when modeling that, would the inductance be in series with the resistor or parallel to it? If it's in series, I'm fine in both instances. If it's in parallel, that will probably be an issue in the damped shunt leg on the LP.
You would model the stray inductance in series with the resistance. I find it hard to believe that Dale resistor has that high of inductance. I would expect it to be more like an order of magnitude lower, like 11 uH.
Good to know! I think it's probably too low for my meter to read accurately. Even if it really is 0.11mh in series, the difference in the modeled response is on the order of .25dB around the crossover region. I do find it odd that none of the data sheets I pulled from Mouser had any inductance specs. One did say "low inductance" but that was it. Lots of graphs showing thermal performance. I did learn these are good for a continuous long-term 20W without a heatsink, so I should be fine in that regard.
I'm with Craig on this one. I would bet it's even lower than 11uh if it's a small value resistor.
