Guy at work gave me a pop up style ice shack for free , but it did need some work . Long story short , I replaced the two poles that had broke. After I set it up I studied the design a little bit and figured out that when you collapse the shack ( it folds in on itself ) that the ball and socket joints kind of bind up, and Im sure get worse when things get ice build up even though the joints are inside of the shack. The ball sockets are made of nylon plastic type of material. My thought was to lube those sockets with something . Do any of you know of a low temp lube that will stay viscous in low temp weather ( 0 degrees and below)? Thought about maybe graphite ?
If it is constructed something like aluminum on nylon, you could inspect the aluminum for signs of galling or other deformation.
You could try inspecting for mechanical binding within the entire assembly, as well.
Otherwise, avoid any petroleum or primarily petroleum based or petroleum like lubricants - stick with vegetable oil (really) or WD-40.
My advice is to see why the sockets are binding. Might be a plastic molding line that need to be trimmed and smoothed.
https://www.amazon.com/Ap-Outdoors-Xtreme-Ice-Xi3/dp/B003VURN8I
