f(s) = 72.67 Hz
Q(ms) = 9.257
V(as) = 10.33 liters (0.365 cubic feet)
n(0) = 0.62 %
M(ms) = 12.24 grams
R(e) = 6.93 Ohms
Q(es) = 0.614
SPL = 89.99 dB SPL 1W/1m
C(ms) = 0.39 mm/N
Piston Diameter = 132.1 mm
Z(max) = 111.37 Ohms
Q(ts) = 0.576
L(e) = 0.150 mH at 10kHz
SPL = 90.61 dB SPL 2.83 Vrms
BL = 7.94
f(s) = 49.12 Hz
Q(ms) = 6.463
V(as) = 22.72 liters
n(0) = 0.55 %
M(ms) = 12.18 grams
R(e) = 6.96 Ohms
Q(es) = 0.469
SPL = 89.48 dB SPL 1W/1m
C(ms) = 0.86 mm/N
Z(max) = 102.89 Ohms
Q(ts) = 0.437
SPL = 90.08 dB SPL 2.83 Vrms
BL = 7.47
Qms is MUCH higher on the first one, and meas Vas reflects that, along with a higher Fs. Are they broken in?
I'd flex the suspensions, and remeasure.
Rival Acoustics RO182-OKL-08 (OEM) Same basket as Wavecor
Kevlar cone with Bimax spider
f(s) = 49.12 Hz
Q(ms) = 5.205
V(as) = 17.90 liters (0.632 cubic feet)
n(0) = 0.42 %
M(ms) = 15.46 grams
R(e) = 7.00 Ohms
Q(es) = 0.476
SPL = 88.38 dB SPL 1W/1m
C(ms) = 0.68 mm/N
Z(max) = 83.50 Ohms
Q(ts) = 0.436
L(e) = 0.148 mH at 10kHz
SPL = 88.96 dB SPL 2.83 Vrms
BL = 8.37
Rival Acoustics R176-CPB-08 (OEM)
Paper cone with Bimax spider
f(s) = 39.03 Hz
Q(ms) = 5.329
V(as) = 24.38 liters (0.861 cubic feet)
n(0) = 0.32 %
M(ms) = 17.98 grams
R(e) = 7.06 Ohms
Q(es) = 0.433
SPL = 87.14 dB SPL 1W/1m
C(ms) = 0.93 mm/N
Z(max) = 93.88 Ohms
Q(ts) = 0.401
L(e) = 0.147 mH at 10kHz
SPL = 87.68 dB SPL 2.83 Vrms
BL = 8.48
