The main issue I have come across is the need for the tube amp to always have a load… also would be great if included adjustable output to balance the levels to the amps
Not so much to be used as an A/B test unit (as flipping tubes on and off cause havoc), but when watching TV (if not a concert, etc.) no need to warm up the room with a tube amp…
Can I assume using Y splitters from the pre-amp signal out to both amps – where only one on at a time- is not as issue? Or do both the input and outputs need to be completely separated?
Thanks
Andy
Hard to say if you really need to switch the inputs. Most tube amps have a fairly high input impedance, so in parallel with the SS amp, it probably won't drop the imp down to a point where your preamp would have a problem driving it.
Highly agreed. If you want to scale for switching both leads, I built a 3-pair relay-driven speaker switcher awhile back (see above). Since mine is for speakers, I used a common negative.
You need a PC PSU, with both 5V/12V supplies if you build like I did. Anything more than 60W is likely adequate. 5VDC runs the LED indication of what is currently engaged, and the 12VDC runs the relays.
The problem will be the mandatory load of the tube amp outputs. Will a Boucherot (CR filter of 0.047uF/12ohm) cell be a sufficient load for a tube amp? I really don't know the answer to that. I included them on the input to the switcher so that amplifiers used are always terminated while make/break occurs. I also have avalanche PTCs (Z131-20UL) across the outputs and 5A fuses at the input after the CR Boucherot.
I used high current SPST Bosch-style automotive relays, but really, anything over 30A should have low enough contact resistance.
I'm sure something could be adapted to work for you using 8x SPST relays for both +/- connections. I had help from several sources to make sure this was stable and secure, even though it should not be switched under high output load if at all possible. If running a few watts, I have no doubt it will function as it should as constructed.
Thanks for your input. Probably best for me to just set-up a series of DPDTs and have both amps off before toggling...
