Generally baffle diffraction creates a broad peak around 800-1200Hz depending on the baffle shape and size, location of driver etc. Don't just take my word for it though, it takes only minutes to generate the graphs yourself:
Thanks gents , I actually found a link a few minutes ago that had this driver mounted on a 10.5 inch baffle and it doesnt really look all that bad . If you google "vifa M21WO-39" and click on images you will see a FR graph of the driver baffle loaded. I did down load the exe's listed above as well. Thank you all
