Happy New Year Everyone!
I am looking for any suggestions for a woofer for a classic 3 way (40L) with Transducer Labs tweeters and Audax HM130z0 midrange. Normally I would start with the woofer, but this is kind of a "bargain" leftover build...bargain only in that I got nice deals on these. I already have some Audax Am210z2s I could use but they have limited bass potential and the SPL may be low, but if the transition from mids to midbass is worth it due to both being aerogels, maybe a subwoofer is worth it. Aesthetically, it looks nice anyway.
Should I be looking at Pro woofers like the
Faital Pro 12PR320 at 96db?
Any other suggestions?
Audax HM130z0 Specifications: • Power handling: 50 watts RMS/70 watts max • Voice coil diameter: 1" • Voice coil inductance: 0.22 mH • Impedance: 8 ohms • DC resistance: 6.4 ohms • Frequency response: 70-5,500 Hz • Magnet weight: 12 oz. • Fs: 68 Hz • SPL: 92 dB 1W/1m • Vas: 0.29 cu. ft. • Qms: 12.16 • Qes: 0.31 • Qts: 0.31 • Xmax: 2.0 mm • Net weight: 2.5 lbs
Audax AM210z2 Specifications: • Power handling: 70 watts RMS/100 watts max • Voice coil diameter: 1-1/2" • Voice coil inductance: 1.39 mH • Nominal impedance: 8 ohms • Re: 6.4 • Frequency range: 31-3,500 Hz • Magnet weight: 20 oz. • Fs: 31.3 Hz • SPL: 90.6 dB 2.83V/1m • Vas: 3.13 cu. ft. • Qms: 3.00 • Qes: 0.36 • Qts: 0.32 • Xmax: 4.4 mm
RSS315 HF-4 or HO-4
DS315-8
DSA315-8
Peerless 830869
Peerless 830669 (borderline for me)
