I have settled into building solid wood baffles that are about 2 inches thick, face glued strips.
To flatten them, I use my router with a jig on a flat, smooth surface.
https://drive.google.com/open?id=1APyxJcPluOFIPdICNC2OYXbzqDuBQpolI need to be able to plane down larger baffles, so I'm thinking about building a special
flat work surface about 2' x 4 ' I have a lot of choice of materials, but I was thinking that
2 sheets of 3/4 MDF glued together and sealed with shellac and wax might provide a
very stable surface. maybe use a laminate (formica) piece, but I'm not sure that dissimilar
materials will be stable in the long run.
Or should I make up a matrix frame with 2x4s and screw down 3/4 inch baltic birch to the frame?
What do you shop experts think of this? Thanks in advance.
I would recommend some sort of square reinforcement underneath. Square aluminum tubing can keep things surprisingly flat.
A torsion box is one/another way.
When I made the router circle-jig, I laminated HDF with aluminum reinforcement. It is flat and will stay that way. As long as you can laminate flat, this is a very rigid panel, as well as being very heavy. I used MDF boards to either side, and clamped the perimeter, then laid 25# weights on the center top while it laid atop my table saw- which is flat. For 2' x 4' and 1" thick of 8-ply 1/8" HDF, you will go through about a half gallon of Titebond. Use a blade or trowel to lay out the glue. As long as you have a straight edge clamped on one end, you can lay this up in one shot.
I did this twice with 5-ply, and the second had a bit of bow with 5-ply when dried. So- I reclamped and added 3 more ply to flatten/counteract out the bow. This worked well.
A layer of dry-erase marker-board for the top is inexpensive and durable.
I'd let my MDF panel dry out a week, set it on the 2 x 4 frame then using the straight edge find the high spots in the panel, secure with a drywall screws and shim the low spots between the fame and MDF panel. After that flip it over and PL glue the edges of the 2x4s to the MDF panel. That's gets you a basic flat work bench. I'll be laminating mine with Formica.
I've been flattening some MDF panels by priming with Bin 123 shellac and sanding with 100 grit on a 9 x 11 inch MDF block, but that's for a veneer project.
At first I thought that Wolf nailed it, it's very unlikely that aluminum channel or steel angle iron would
bend, so I checked prices for those at Lowes. Sheesh - "arm and a leg" - so I thought maybe black iron
pipe - just as expensive! - So then I thought about used / surplus / scrap - and a local search found a
Habitat surplus store near where I work.
As far as decibel's suggestion - it's theoretically possible to have a stationary router jig and slide the
work piece under it, but I think that the slightest "jiggle" in the work piece would cause a ripple in the
surface. When I hot glue my baffles to the flat support, I can achieve a very smooth flat surface,
so that's the model that I'm pursuing. Incredible live edge slab, though.
So all possibilities are still on the table. Depends on what I find at the Habitat store.
I'll post build pics when I put it together.
Paid someone to cart it away. Of course, now I need it... <grin>
https://www.8020.net/
https://www.grainger.com/product/29NZ78?gclid=EAIaIQobChMIm5KN0oTc3wIVg7bACh3NuA_hEAQYASABEgIdifD_BwE&cm_mmc=PPC:+Google+PLA&ef_id=EAIaIQobChMIm5KN0oTc3wIVg7bACh3NuA_hEAQYASABEgIdifD_BwE:G:s&s_kwcid=AL!2966!3!50916703317!!!g!71843518639!
(Reason, aluminum can and will bend, not so much for steel.)
Now that I'm in full search mode, Nextdoor has a couple of "curb alerts" for bed (steel) rails.
I might get lucky yet.
it's easy enough to keep the router level. On both of my jigs, I used some pieces of HDPE on the bottom, and they really
help the jig slide smoothly.
Once assembled should be really hard to bend. Am old WW video:
The Nextdoor "curb alerts" were all gone, but I found a Habitat store near my work and
they had about a half dozen steel bed frames. I got an old, heavy angle steel Queen size
frame for $10. Figure I'll cut pieces with a jig saw. Perfect for my needs. They also had
a bunch of light fixtures and tables that would be handy in the shop.
Thanks for all the suggestions!
