I'm trying to convert a 3" x 3.65" round port to a slot port, and need a refresher on how this works. I know that the area of the port needs to be maintained, but don't remember if it's the height (diameter) or length that also stays the same. I've done some searching already, but the explanations I've found (to me anyways) aren't very clear or just gloss over the topic.
TIA
3.1415 × (1.5")^2 = 7.068 in^2 (~ 7 sq in)
If your slot port width is 7", then the slot port height would be
7 sq in / 7" = 1" (7" wide x 1" high)
Or
7 sq in / 3.5" = 2" (3.5" wide x 2" high)
Etc
If you want to really optimize, usual the round ports are in the center away from the walls, whereas slot ports use the walls as one of the side - this does affect the lenght of the port for a particular tuning - Jeff B has a formula for calculating how much of the lenght should be altered if you are near a wall rather than away from a wall (at least twice the diameter of the port... Or just skip it, you will be in the ball park
The other rule of thumb was to keep the height to width ratio no more than 1 to 7, (1 to 9?)
I can't remember the exact end correction/ boundary factor for the slot port, but I've used port length -1 port height multiple times and been very close to the box model.
