I used to use Sketchup (but it's too finicky and doesn't always work, worse for 3D printing as the usually the model is not closed), dabbled a bit in Fusion 360.
I am looking to pickup creating models again and looking for suggestions. It doesn't need to CAD/CAM the universe, but create reliable 2D model which i can export to DXF, to be imported to Vectric/Aspire and solid 3D model which i use for 3D printing, open source or low cost preferred.
if you have suggestions for the full path that is welcome too...
@JasonP does OpenSCAD support both code and UI or is it code only like very very old Autocad? Code sometime helps as you can set very precise parameters instead of trying to place the mouse at a very specific point! What are the export options?
@jhollander what are the export options for NanoCad?
