I made some sawdust toward the 2020 project providing I can go. If not, we’ll at least I used up some drivers! My initial plans for the quad of peerless p830869 woofers was an 8” mtm. This theme got me thinking to keeping that idea but going with an additional rear firing tweeter, but I have a quad of TC9s that I never can settle on a project for, so I thought I’d use them here.
The plan is a pair of the peerless 8 inchers per side in a 2ft3 vented cab, topped with an open baffle dipole mid mtm using the TC9s, with a hivi rt1.3 in the middle. I have all the drivers and started throwing together the cabs today.
The cabs are pretty budget oriented, using menards 3/4” particle board for the sides and back, and left over MDF for the baffles.
(sorry for the out of order pics..)
For now I threw the drivers in so I can take measurements and work on the initial crossover. The cab will be sealed for this part but I should still be able to get a handle on bsc.
https://www.jfcomponents.com/
This: https://diy.midwestaudio.club/discussion/716/68-camaro-install
I wouldn’t want to use those that I already made much above 100 hz or so either as I did nothing to combat inductance and those are 2”, four layer, long, 8 ohm coils, which all made for massive inductance - around 5mh.
From some prelim sims I plan to cross this project around 600 hz. I’d have to build a new set for these and probably wind my own voice coils to get more of a woofer than a sub.
Ive found that playing around with driver building really is teaching me a lot about the different factors that play into ts parameters and the comprises that need to be made just like in enclosure design, etc.
I've been trying to find projects that use 830869's and an MTM with them would be awesome.
I have really bad floor bounce on the woofers at 250hz or so. It is the same at one meter or two. What do you guys do with it? Is there anything? It’s just such a massive suck out in the midbass region.
Here is a pic of the measurement and with filter. Ignore the mountain below 100hz, it was measured at 1m in room with no splicing. The graph is both woofers measured together.
On my open backs I’m running two 12in Ws with the top crossing to the mid and the lower as a ½ way (big coil). This may ? reduce the issue- a bit counterintuitive, but separating the drivers freq a bit may be worth a try? (assuming you don’t want to go active)
