I'm looking to build two big towers for next year. I was looking for any tips for choosing drivers aside from having a good overlap to make the designs easier to accomplish. For example do you try to get all the sensitivities to be close to each other? I agree with JR with having 2 or 3 woofers per side really speaking to me aesthetically but that's not 100 percent necessary. I'm really jumping into the fire with these but I expect to come out with a lot more knowledge gained trying to do 3-4 designs. Like I said any pointers and words of wisdom would be helpful. Here are some drivers I currently have. I noted the sensitivity's for easier reference.
My dad has a pair of Transducer Labs - N26CR2-A (91.5db 2.83v/1m) and a pair of the Sb Acoustics 10" SB29NRX75-6 (88db 2.83v/1m) and we are looking for a really nice mid to mate with it. If you guys have any good suggestions i'm all ears.
I have a few drivers laying around.I'm not sure if the Dayton RSS210HF is best woofer choice but I have a pair.
A Pair of SB-acoustics SB29RDCN-C000-4 (94db 2.83v/1m) neo smaller flanged tweeter
A Pair Vifa NE149-8 ohm 5-1/4" mids (88.2db 2.83v/1m)
A Pair RSS210HF-4 (85.6db 2.83v/1m) Im not opposed to buying woofers for this build. 4x anarchy drivers are tempting.
I have a pair of rs28F and rs28A's too but really don't want to do any more builds with these drivers aside from trying the denovo's rs28 waveguides I bought last year.
You have some great drivers. Weather you choose to use what you have (like the vifas in a sort if a mtmww) or start ground up, take advantage of the dedicated mid in one form or another.
$0.02
I have heard the Vifa mids in Jim Holtz's Finalist design and this weekend in the Micro Statements. I would put their performance level closer to Seas/Scanspeak than the scan disco.
if I was to try this tweeter sb29 http://meniscusaudio.com/sb-sb29rdcn-p-1049.html
This ne149-8 mid
https://www.parts-express.com/peerless-by-tymphany-ne149w-04-5-1-4-full-range-woofer--264-1082
This woofer
http://meniscusaudio.com/sb-sb29nrx756-p-749.html
How do you fella's feel about that?
This build is next in line so it will be starting soon but since im going to meniscus this week i figured id ask everyones oppinions. I hate this design stage because i want to just build them once and not do a test box incase they suck or i dont like a driver im not out like $150 in wood or veneer. Better just build some test cabs for now i guess.
I would recommend building Statement type of the arrangement but without the vented midranges. Instead, I would add rear-firing tweeter with independent L-pad.
TL is a very robust tweeter. however in a 3-way design, very low x-over point between tweeter and midrange is not necessary. I'd look for a smaller format tweeter like Hiq or a planar or ribbon.
