I’m a bit biased towards coax’s (and small full rangers for 300Hz+ coverage, but that’s another post…) and have played around with Celestion 6.5 in., KEF’s, and even the little Dayton Audio CX120 4in.
And I’m a bit intrigued by the extended horn design of the Beyma 5CX200Nd, which attenuates the issue of the high frequencies dealing with a ‘moving waveguide’ (the mid or woofer if you will) as per many designs.
Per its sheet https://www.usspeaker.com/beyma%205cx200nd-1.htm it looks to have fairly smooth off-axis response, and some potential ? for trying a fairly high 1st order crossover point as well.
Any thoughts? Thx
http://www.bmsspeakers.com/index.php?id=bms_5cn1620
I'm thinking these might pair up with the MCM 8s you recommended, and now are sitting in my basement waiting patiently…
I actually have the 12BR70s in my current open-back speakers (2 per side) and have been very happy with their performance. But the better half 'offered up' to me they are pushing the limit (aka WAF, but I didn't let her in on that technical speaker acronym…). So I'll take this as an opportunity to get started on another project, thinking something size-wise along the lines of the Harbeth Monitor 30.2’s (approx 11in x18in, by what depth models out), so the 8s will fit the bill... and perhaps on a ~JBL l100 style stands...
The posted frequency pic was measured at ~30in, 15 deg off axis, using an Lpad and a simple cap and coil
I've been playing with values for the cap/coil, and have been using an Lpad to adjust the tw level, but problematically find that the Lpad is affecting / limiting the roll-off slope of the tweeter?
FYI
I've been listening /comparing the beyma coaxial 5’s (for the mid/ top-end of a dual 12in beyma's woofer open back speaker set-up) on the left channel vs. the Celestion 6.5in coaxial on the right.
An advantage of the miniDSP to bi-amp (active crossover btwn woofers and coaxs) is I can additionally DSP both channels to ~equilivant flat frequency and level response (measured at 15 degrees off axis).
While I find both the Celestion and the beyma to provide solid, clean mid/hi (I cross each passively above 5gHz) I find the beyma’s with its extended tweeter horn design (the Celestion is also a horn design but terminates at the mid cone) to provide a bit broader off-axis control (less sharp roll-off).
Coax’s provide some Xover challenges, but vs. displacement issues of seperated mid/tweeter designs…
