There has been some interest in this little (and I do say LITTLE) guy.
https://www.parts-express.com/gento-sp99023a-2-paper-cone-full-range-speaker-4-ohm--299-546 Fs is quite a bit higher than specified, but generally pretty smooth, and with surprisingly low distortion.
Not sure how I could add mass to the little cone for independent T/S specs, so nothing on that front.
Pretty efficient, should make for a nice CBT array, but the terminals are TINY, and do not look amenable to a press fit connector.
Good airflow for a pressed steel basket
I would have measured closer, but that has the tendency to roll off the highs, and I wanted to capture that range.
Hot glued roughly to a small PE box, stuffed with some polyfill. Driver flange maybe 1/6 above surface.
The problem to me is the high Fs - 350Hz is lot higher than 150-200. You wouldn't want to run a sub up to 400 or so, you'd need a woofer Dunno.
And yeah, I'll need a nice 12 inch sub for it.
