I need to build another center channel as friends and family keep taking mine. So as long as we are asking opinions about designs, which one do you like? I like to build matching mains as long as I'm cutting wood. The front baffle is 5" x 19"
For the center channel design I'm targeting a second order LR with a low (1,500 Hz) x-o point. With my test x-os I will measure off axis to see what changes and then change my x-o point and slopes.
I will treat the MTM as a measure as 1 woofer and use actual measurements to look for problems off axis. I'm contemplating using the 3.5 inch Tectonic drivers so I don't see any value separating woofers and using PCD to look off axis.
That said, in the past I have dummied in driver parameters in PCD and tested my x-os off axis with PCD. I think you can get a good feel if your x-o is going to put a dip in the response.
A!
How about version "E", with the two thin slot port exists located on the rear of the cabinet?
Rear of the speaker ports are a no go for mounting the speaker in TV cabinets
A for center, D for LR.
Same
what Silver1omo and DanP said...
A or B, option E would put two small ports under the tweeter and between the tweeter and woofers.
I'm with those guys^^^. A center, D for LR.
I think the challenge is picking one to do both. The stand for placing on a stand is also a design element.
I'm contemplating using my least favorite Dayton woofer series the DSA115-8. This is kind of the last chance for this series, I can only be disappointed so many times...
That's a lot of woofers to use for a woofer that's not a top pick.
Yes, but I have two, they model very well, and I haven't spent time listening to them. It took me several weeks to develop a dislike for the DSA175 and DSA135, so I'm hopeful these can go the distance...
Actual progress
So to pick your brain, and I know you have had experience across at least two of these. How would you compare the Dayton DSA, DS, and RS drivers you've heard? I have only heard one DSA (it sounded ok in JR's build) and several DS due to KennyK, and I've used more than one RS myself. Myself I think perhaps the line is de-volving? RS > DS > DSA. I have no data to back that up though.
Besides that loaded question, build work looks stunning!
Might as well throw in the DA series too. I keep trying to like the DS and DSA series. I don't think I have comparable distortion measurements, but it must be the DS and DSA breakup that is bothering me. I don't like them compared to the RS series. I lean more to liking the DSA over the DS. I've only heard the DAs in multiples and thought they were a decent value.
I don't see why PE makes all of these. There's not enough separation in price or sound to be meaningful in my opinion.
As I mentioned above this is the last shot with the DSA series. I'm probably becoming cynical in my old age, but like others here I'm gravitating toward more expensive woofers.
Between house projects I get to work on these. I'm happy with the baffle. The surface mount DSA frame is a bonus. The DSA115s have very tight rear/ under cone venting. My back up are RS100s, but they would not look good surface mounted.
Some glare on the last pic
I had experimented with the DSA driver frames a few months back - I put a bunch of sound deadening material on the baskets and it made a difference in the driver distortion sweeps. Might be worth a try if you can get some sound deadener.
Spent 3 days on this. Mostly on the mains then the center channel. I'm tired of lumpy responses. Anyway the two DSA115 sound pretty good with the RST28A.
The long narrow baffle doesn't translate well going from vertical to horizontal. I ended up remeasuring with a dummy cardboard entertainment center. This worked well for the off axis measurements. Both x-os ended up being LR4s at 1,500 hz.
This is the vertical mains 0 to 30
Test setup
Tiny .01 mh inductor
Side note, the RST28A seemed like it had less sensitivity than I would have expected. I felt it ran 2 dB less than advertised
