I don't understand Craig's response, nor do I understand the restate of the OP. The Halcyon is not a private design.
The design Dave Thomas posted back in 2012 is likely no slouch. However, I might move the series resistor out front and play with the value to minimize the impedance-phase swing.
You "Tree'd" me. A common term in drag racing when one driver has a quicker reaction time. A reference to the starting line lights called the "Christmas Tree".
I initially thought that tree'd was just another design using the SB17NRX2C35. Had to google Halcyon to find out that that was a Curt C. design. tree'd might be a good name for a speaker with a laid back type sound quality.
Halcyon....
Tree'd
Any open-source 2-way designs with the SB Acoustics SB17NRX2C35-8 woofer?
There is a design posted on Tech Talk
https://techtalk.parts-express.com/forum/tech-talk-forum/49256-sb-acoustics-sb17nrxc35-8?229978-SB-Acoustics-SB17NRXC35-8=#post713683
amps lab will send you the schematics for the 4ohm version:
https://ampslab.com/blog/2021/01/26/magpie/
driver measurements on v1 vs v2
http://www.audioexcite.com/?p=7167
the Elsinore project uses V1:
http://www.customanalogue.com/elsinore/elsinore_index.htm
So, I didn't find anything open source on the V2
Picture of said "Tree":
And how they started the race before said tree:
Okay, now I understand the lingo. I'm familiar, just had no indication it's what you meant.
Yes, you posted exactly what I was going to post a moment before I had a chance to
this is what I thought first
https://www.dusupply.com/bear-treed-decal-2818.html
