I used up the last of my 2.75 inch cardboard tubes. I have 2.5 inch and 3 inch but would like to find something less than 3 inch. Anyone have a source?
I recently ordered two 11 ⅞ length for my current project. They cut down nicely on my table saw (supported / tape between two small wood pieces), cut inside at 30 degrees. I couldn't find cardboard in that diameter.
How long do you need? I have a 3D printer.
About 8 inches long.
If I had 8 inches I'd be king. I can print something that big. How soon do you need it?
Ron, thanks but hold off for a bit. I've got another idea (slot port).
Also, 3-inch dia PVC pipe port length will fit in the cabinet which is the back up.
edited this sentence
https://www.estreetplastics.com/Acrylic-Tube-p/et0300027524.htm
