Using drivers in "up-firing" orientation - thoughts?
Hello All! Hope you are doing well. I'm working on a design for a two-woofer system that will be used in low-slung box. It's the woofer part of the loudspeaker only. One configuration that I have been considering is placing both woofers on the top of the cabinet, which measures 60x120cm (about 2x4 feet).
It's been a very long time since I have considered using a driver in a non-horizontal orientation. Modern drivers do not have suspensions as soft as those from long ago, so sag is probably not too much of a concern. I am more worried about increased distortion in this orientation. Has anyone looked into that in DIY circles?
Would love to hear some thoughts on this topic. Thanks and happy holidays!
-Charlie
P.S. the driver is the SB Acoustics SB23MFCL45-4
  • If they are being used as subwoofers playing under 200hz in a sealed cabinet I doubt distortion would be affected. At higher frequencies, the horizontal orientation will be complicated to work with.
  • Distortion from difference in apparent motor force due to gravity?
  • I am hoping to use the drivers from 30Hz to 300Hz.
    Yes, the effect is due to gravity acting on the moving mass. It assists down acceleration and resists up acceleration, so it is IIRC increasing even order distortion. But by how much I do not know.
    Maybe this is not worth worrying about with modern drivers...
  • Resrc - How to Tell if a Woofer Can Be Mounted Up- or Down-Firing. In PE tech resources
  • Sounds like an omni woofer project. I've been playing around a little with the Dayton Audio GF180-4, and now with the buyout SIG180-4. Both firing straight up with the OB mids and tweeter directly above the woofers. Thread here:
    https://diy.midwestaudio.club/discussion/2777/pwrryds-omni-ob-whatever-thread/p1
    I've let other projects get in the way and haven't even taken the new measurements yet. Initial playing around with the cheap GF180, no issues playing them to 500 Hz. I have some days off work so I might jump back on this project before the new year.
  • @Eggguy I use Unibox for quick TS modeling and it has that built it. Comes to 0.97 e.g. 3% sag, so no problem there.
    @PWRRYD This setup uses two woofer that are separated by about 12" to 16" C-to-C and operated as a dipole at "high" frequency, e.g. above 200Hz. A filter is used to manipulate the phase of one driver, which causes the radiation pattern to change from dipole to cardioid to monopole (in phase) with decreasing frequency. I have modeled this about 10 years ago, then better more recently and I finally want to build it. The advantage is that you get a dipole pattern that will match that of a dipole mid, but then the output becomes monopole at LF and you get room pressurization without dipole losses. I am just trying to decide on where to place the two drivers and two PRs on the cabinet so that they have the correct spacing and are still ground coupled. Putting them on the sides at the ground makes them a little too far apart (over 24"). Then there is the option to put them both on the top, facing up. The third option I am considering is making two separate cabs, each half the volume (since each will only have one driver and one PR), which will be like two cubes. The cabs would be placed with the drivers facing each other with about 12" of air in between. This creates a "slot" that will likely resonate but I would have the flexibility to move the cabs and drivers closer together or farther apart. I can't actually build anything until the springtime due to no heat in the work area, so I have too much time to think!
  • Yeah way different than what I'm playing around with.
  • edited December 2024
    So above 200 Hz you should expect to get some directionality based on the placement of the woofers. I'd be concerned about the room interactions, which would make the design specific to one location.
    The two woofer boxes gives you the most flexibility. A typical cardioid woofer doesn't deliver the same alignment? A drawing would probably help.
  • Hey Charlie, are you in Germany now?
  • That is what his flag designation is over on DIYaudio.
    Yes, have been over here since May 1.
    Steve_Leekenrhodes
    The two-woofer setup will be operated as a dipole in the upper part of its passband (eg 150Hz and above). If you take two monopoles, reverse the phase of the "rear" one and move them apart in space this gives rise to a dipole radiation pattern. Despite using two monopoles, you get more and more cancellation at the on axis listening location with decreasing frequency. This is because the separation between the two sources that are 180 degrees out of phase becomes less and less of a wavelength at lower and lower frequencies. Thus you get the classic 6dB per octave fall off due to the interaction between the output of the two woofers. As you get below 100Hz you add to that the rolloff of each driver's LF alignment, e.g. sealed, vented, etc. For example if it is a sealed box, the rolloff would increase from 6dB to 18dB/oct with the addition of the CB rolloff. These LF losses can really add up. You can equalize the response within the 6dB/oct rolloff region to be flat via passive or active means, but the losses eat up Xmax and sensitivity.
    It would be nice if you could avoid the LF losses and it turns out that if you can just change the radiation pattern into two monopoles you do exactly that. So I have come up with a way to use an allpass filter that provides the correct phase rotation to transition over from dipole at HF to two monopoles at LF. The monopoles are in relative phase but the front one lags by 360 degrees at the lowest frequencies, below 60Hz.
    It is possible to just sum a monopole and dipole to get a cardioid. If you cross over between the two this is another way to transition from dipole to monopole. The problem is that this only applies to a dipole that has already been equalized to be flat and to have the same gain as the monopole before summing them. This puts a lot of demand on the dipole which means either a large driver or a large baffle. So I am investigating this other way with the two woofers and the AP filter. In either case you want the system to have a dipole radiation pattern where you cross over to the midrange.
    By combining the multi-pattern woofer system with a 6" class cone midrange (nude) and an AMT dipole tweeter I can make a system with 3 bands. Technically it is a 4-way since each woofer has a different input signal due to the AP filter used on one of them. But this will allow me to put the two woofers at the floor, and then place the mid and tweeter above with nothing in between but air. This helps the front wall reflection return to the listener without diffracting off of some big ass baffle, which IMO ruins the imaging effect of a nice dipole system and is why I am not in favor of large planar dipole/OB systems, e.g. PAP, etc.
    Silver1omo6thplanetSteve_Leeugly_woofer
  • That's sounds pretty bitchin, Charlie. To bad your not around to demo at one of the events.....if it all pans out.
  • Very well elucidated as usual, Mr. Laub.
    (I actually understood it).
  • @6thplanet said:
    ...To bad your not around to demo at one of the events...
    I assume Charlie is organizing Deutschland DIY for us.
    Steve_Leekenrhodes6thplanet
  • I don't have empirical data, but I could generate some.
    A simple test might be to measure a woofer in box, in the frequency of interest eg. 10-1KHz, in the horizontal position, and rotate the box such that the woofers is in the vertical position.
    However, whatever result I might get not be applicable to your use case, or generalizable to other use cases (external validity)
    The reason I believe this is that in many (sub)woofer measurements that I've seen, Kms (x) is rarely perfectly linear and thus not symmetrical. Usually there is a bit of coil-in or coil-out offset, that is, where there is a higher stiffness when the cone is pushed out, compared to when the come is pushed in.
    So whether mounting the woofer vertically exacerbates or alleviates that, through the effects of the gravity on the moving mass... and then there is time...
    charlielaub
  • Not that I plan to try it, but there is a cool technique to correct cone sag: You place two very large value el-caps on either side of the driver. This AC couples it to the amplifier but DC will be blocked from passing in or out. Then you use a current source to flow a small current through the voice coil within/between the two caps. The current is chosen to cause the cone to "move upwards" exactly enough to offset the cone sag. This would really be some extreme DIY but a fun experiment nonetheless. The cap values need to be very large so that they do not roll off the low frequencies too much (e.g. 22kuF), and the voltage rating should probably be at least 63V or higher. Those parts are not cheap, so it is a lot of cost for a small gain in performance.
    4thtry
  • Recently, I was writing down the various projects that I have dreamed up for 2025 (I do this every year, like a new years' resolution kind of thing) and then mulling over each one. I realized that I can use the exact same woofer section for another project if I build it as two separate boxes (per side, four total), each with a PR. So I will use a pair, face to face, instead of up-facing.
    But in the "other" system I WILL use the method for generating a a cardioid that combines a monopole driver and a dipole, with the woofer up-firing directly below the mid.
    I will be able to make a comparison between forward and upward firing in terms of distortion, which will be interesting in itself.
    The 8" woofer + 12" PR setup is perfect for double-duty in these projects. I purchased the drivers already, so it looks like my plans are finalized.
    Eggguy4thtrykenrhodesSteve_Lee6thplanetjohnny5jz
  • Can't wait to see the results!
  • Me too... Sadly, I currently have exactly zero DIY speakers. But after hauling a bunch of drivers and gear over here to Germany last summer I am finally getting the urge to build something again.
    Steve_Leekenrhodesjhollander4thtry6thplanet
