Is that actually a 6N1P? If so, those that I've come across are really good sounding tubes...but that was back when Svetlana was still in business.
I do have a bunch of 6DJ8's - mostly orange globe Amperex or Bugle Boy. Most were good pulls from old tube scopes and medical equipment. Not sure if I have any Mullards. Do you just need one Bryan? Heck, if it's a single, I'll just send one. Not sure what brand it might be, but I'll run a few through the tube tester to find one that's decently balanced side to side.
Found the tube you have pictured - it's a Shuguang 6N1(P). It's not a true sub for the 6DJ8 - it's pinout is the same and I think most operating points are in the ballpark. But I do know they draw more heater current and that can be a problem in some gear designed for the 6DJ8. If you run it, check your power transformer to make sure it's not starting to cook.
From what I understand, the 6N1 (Chinese) is the same basic tube as the 6N1P (Russian). They draw twice the heater current of a 6DJ8, about 600ma. The 6N11 is a copy of the 6922, which is an industrial grade 6DJ8. Same heater current as the 6DJ8.
PM me your address and I'll test a few tubes this weekend and send something your way. They might not be pretty, but I'll test them for microphonics in my little tube linestage too.
The 6DJ8 Mullard I used in my tube buffer died and this (Russian tube) apparently was the original that came with the unit.
https://tubedepot.com/products/6dj8-ecc88-jan-sylvania
The only gear I have that uses tubes is a Yaqin CD1 and yeah it only has one tube. It’s supposed to be compatible with 6N1 as well as 6DJ8s.
So do all 6N1 tubes draw more current?
I’d love to try a couple different tubes just for fun.
