These followed me home from an estate sale today:
I bought them because the cabinets are in really good shape and was thinking I could reuse them.
I listened to them for a while tonight. When they were out in the room they sounded very thin and bright, they sounded much better after I placed them up against the wall. Overall they don't sound too bad, a little light in the bass and maybe still a little bright, but not terrible.
I am still leaning towards repurposing the cabinets, what do you all think?
You can rebuild them and make them better.
Just do it.
Sure Looks ripe for a classic 3 way.
But before you repurpose them, are you able to measure them?
I read that interview that someone kindly linked re: Bob Gault/Eminence. My takeaway was that it’s remarkable what that those achievements were made prior to the days of computer software modelling. The most he ever used was a calculator! Thiele/Small Parameters hadn’t even been discovered yet, and musicians and engineers and physics majors were going by ear (or trial and error) alone!
This is probably the same vintage (1960s design). A classic whose info could be added to:
https://www.hifiengine.com/manual_library/sansui/sp-30.shtml
I'd give them some more listening time, the drivers may be a little stiff from minimal use over the years.
This is how my pair measure:
I have decided that I am going to repurpose the cabinets, just need to come up with a plan.
Are these ^ graphs of two different speakers with two different scales applied?
They do lack bottom-end for sure so re-purposing them looks like a good idea.
Two different speakers, same scale, but centered in the window differently.
They certainly lack bottom end.
You could always use them as MT's with a sub and EQ them flatter . . .
Those cabs are nice - definitely worth some new drivers and XO's.
These will probably end up in our spare bedroom listening space. It is not set up for a sub in there, with no current plans to do so.
The cabs are very nice, that's why I couldn't pass them up.
I came up with my plan for these.
Since they are a 6-1/2" paper cone woofer with a waveguide tweeter, I am going to stick to that formula.
Woofer is going to be the Dayton DC160-8. I have a pair of these on hand and they are a bolt-in. The mounting holes actually line up and I can even use the existing mounting hardware. Gross volume on the cabinets is around 15l/.5 cu ft, so F3 will be somewhere in the low 40s.
Going use the Dayton ND25FW waveguide tweeter.
The cabinet walls are 1/2" plywood, so I am going to add some internal braces and may or may not glue in some 1/4 mdf to increase the thickness of some of the panels. Probably just going to do braces though.
I'd just add some extra bracing. Adding 1/4" MDF isn't worth the effort IMO.
+1 for ^
Some teardown pictures.
Tweeter and crossover (the woofer was run full range):
It looks like they found a use for the woofer cutout scraps:
back panel:
Did you see the thread I made regarding the pair of Sansui's my neighbor gifted me?
...and you gifted me.😉
Just searched for it, definitely a family resemblance
After removing the drivers, I noticed that the baffle is made from 9mm plywood. Then I took another look at the back panel and it is made from 9mm too.
I built new cabinets for my wife's cousins Sansui SP-1200. Pain in the ass. Water damage. One had a bad woofer, and the replacement he bought was bad so he had to buy another one. SQ wise they were garbage, I convinced him to let me build him a pair of the Le Singe Sarcophage and he was absolutely floored.
This is a cool re-purpose project and should be light years improved over the original complement.
I have always had a pair of monkey coffins in the back of my mind. I have no space for them, don't know what I would do with them, but I want to build a pair.
Thinking 12" GRS Poly woofer (or the subwoofer if it works OK in a little bit smaller box), 6 1/2 GRS poly for the mid and not sure about the tweeter.
I could build a pair of the Le Singe Sarcophage, but I kinda want to roll my own.
But that's a project for another day.
I like the Dayton Designer Series tweeter for an inexpensive option. The GRS 1" dome is also solid for the money. I used it in the Cabrini Redux project. The GRS 6.5" poly woofer is outstanding IMHO. I think you could make a killer coffin using the 12" poly woofer, the 6.5, and the Dayton tweeter.
