I started building these in 1991. When the cabinets were about 80% finished, I got sidetracked on another project. And for some reason or another, I never came back. The unfinished cabinets sat in storage, collecting dust, for the next 26 years!
The original driver cutouts were for DYnaudio drivers, but they were never mounted.
Last month, as I walked past these old cabs, I noticed that the woofer cutouts seemed close to the SB Acoustics Satori woofers I had on hand. The old cabinet used a traditional style TL and I wondered if I could re-tune it and make it work as a modern day ML-TL?
So I ran some ML-TL alignments using the LA beta TL software package and found that a slightly drooping, soft knee low frequency alignment, good to about 30Hz, could be created in this box. All I had to do was to make a few relatively simple changes to the overall length, port location, and stuffing plan.
Here are some pics of the old cabinets, taken in 1991. Sorry for the poor quality; I scanned the negatives and cleaned them up as best I could.
Thanks for looking. I'll stop back later with xover, measurements & a few current pictures.
Bill
Great project!
It is the Leonard Audio Transmission Line program. There was a long thread about this program on www.diyaudio.com and PETT a few years ago. The program was a free download, but has not been updated since 2014. I am using version 3.6.3.5. Here is a link if you want to check it out. I don't know if this link still works.
http://leonardaudio.co.uk/
I moved the port down and added a PE 268-368 PSP3OFH 3" outside type flare to the end of a 2.5" PVC elbow. The PVC elbow is actually 2.9" ID and is butt joined to the flare. I then added a short piece of 2.5" ID PVC pipe, which makes the total port length about 8 inches. I made a gasket for it out of 1/16" foam sheet material from Michaels craft store.
I butt joined this flare to the 2.9" ID elbow and then silicone rubber cemented it in place. Then I cut a 1 inch long piece of PVC from a length of 3" ID stuff I had on hand. Then I cut this 1 inch
ring into 4 separate pieces on my band saw and made a silicone rubber reinforced junction. I was very generous with the silicone and when it cures completely this should produce a very strong joint between the black PE flare and the PVC elbow.
The top crossover board is for the other channel's tweeter. This board slides into the slot just above the needle nose pliers. This gives me easy access to the tweeter board for mods. Just pull it out, re-solder, and go!
The bottom crossover board is for the woofer. If flips into the access hole just above it:
Note: I had to grind a little material off this 3.3mH P-core inductor to that it would fit in place when I flipped the board in place. Grinding this small amount of material off reduced the measured inductance by about 1% from 3.38 to 3.34mH. This did not affect the FR graph at all.
I glued some backer boards inside the cabinet behind the old TL terminus hole and then sealed up the old opening with a plug. This plug can be removed to adjust stuffing. I have a small amount of stuffing at the end of the line to act as a trap. The new terminus/port was moved to the bottom of the enclosure.
I agree. I guess it is a beer budget from my perspective alone. JR gave me the tweeters and I scored the Satori woofers as a door prize at InDIYana 2016. I built most of the cabinets in 1991, so my current cost for lumber was almost zero. And my PE order for crossover parts was roughly $100. I'd call that a beer budget!
Description: Floor standing two way using a 70" ML-TL on the woofer and a traditional
30" TL on the tweeter.
Drivers: SB Acoustics Satori MW16P-8 6.5" woofer
Dayton Esoteric ES25Nd-4 Tweeter
Crossover: 1.1kHz @ 12dB octave on tweeter and 6dB/octave on woofer (electrical)
Zobel FR shaping networks on both woofer & tweeter. HF tank on woofer.
Sensitivity: 87dB @ 2.83V/1 meter
Woofer loading: 70" ML-TL tuned to 29Hz. Constant cross section of 5.5x6.75". 2.9" ID
port elbow approx 8" long. Stuffing density and location adjusted per model.
Tweeter loading: 30" traditional TL designed to absorb as much of the rear wave from the
tweeter as possible, thus reducing the amount of midrange energy reflecting
back to the tweeter cone. The cross sectional area is tapered from
2.19x6.75" at the beginning to 1.62x6.75" at the terminus.
Size: External: 49" H x 8.5" W x 13.25" D
Baffle: 8.5" W x 48" H overall
Woofer: 35.5" up from bottom, centered
Tweeter: 43.25" up from bottom, centered
Weight: 73 lbs each on my uncalibrated bathroom scales.
Test setup:
For the verticals, a 5 to 6dB depression occurs in the 1-2kHz region on the blue, -20 degree curve. This is the result of my crossover design which causes the vertical lobe to point upward. This depression is what you would hear if you were sitting on the floor in front of the speaker. The black curve is what you would hear sitting in a chair. And the red curve is what you would hear when standing.
Here is a graph showing the average of 24 horizontal curves. I turned the turntable 15 degrees for each measurement, spinning it a full 360 degrees.
And, finally, here is an averaged listening window graph. I averaged 18 measurements, taken at a distance of 2 meters, inside a wide 4x6' window:
Side & Front View:
Tweeter Side View:
Update:
Based on the Dakota event listening session, I modified my Dual Exhaust speakers by shortening the port by about 3 inches, reducing the stuffing density in the front half, boosting the stuffing in the trap area, and increasing the length of the unstuffed area. Below is the TL model showing before and after modifications.
Before modification:
After modification:
They now have more deep bass below 100Hz when placed 8 feet from the rear wall. Thanks to everyone at Dakota for allowing me to move my speakers forward and backward during playback. This helped me a great deal to "hear" and correct the problem. The port output is now roughly 3dB higher below 100Hz and is re-tuned from 28 up to 32Hz (no more drooping response below 100Hz).
To review, I attempted to attach the following images with no luck. They all have the .jpg extension and are fairly small (191 to 240KB):
_DS50968.jpg 225KB
_DS50957.jpg 240KB
_DS50959.jpg 191KB
_DS50987.jpg 194KB
_DS50999.jpg 191KB
I will wait 5 minutes, log in and out, and try attaching again
Bill
