As I'm finally getting started on this monster speaker, I'll record my progress here (with pics!). All in the final design stage now, here is what I've got:
Design is a tall monster: S/WW/MT/WW
Starting from the treble and working down:
T: Viawave small ribbon RT850. Sounded great in JR's Taiga.
M: Scan 15M/4264G. Not a revelator or anything, but high sensitivity, phase plug, foam surround. Response looks very very flat.
WWWW: MCM 55-2669. Lots of them. Clean midbass driver, but doesn't dig deep. Going to put them in a resistive type cardioid setup.
A: Dayton's RSS460HO-4. 18" sub, works well in 75L sealed (F3 <40 hz), is sensitive enough to keep up with the rest.
Doing enclosure design now.
John: I'm still exploring how the front baffle will work. I'm not sure any advantage is gained from that box type for the mid? Time will tell.
I consider cardioid to be controlled dipole response. The rear loading can be tailored between a dipole and oversized sealed enclosure. I recall using horn response to attempt to model the woofer loading.
As you have rear radiation, you can get the openness of a dipole without the placement issues. By using a cardioid mid you would be at the frequencies where you can hear the openness. Below 1,000 or so Hz, the sound is not that detectable.
The downside is you have to repetitively adjust and test to get the rear wave and x-o right, but it sounds like fun. This has been on my list to try for awhile. I'm looking forward to seeing what you come up with.
Am I reading correctly that the sub will be passive?
