Finally got around to working on the MCM Gradient axp-06 6.5" project. Bought a few of these very reasonable when MCM went under.
This is what DATS said of the 6.5" axp-06. Ugh ... the midrange chamber was stuffed with denim insulation and triangular shaped, why all the squiggles?
So decided to get a free air measurement.
Is this going to be a problem?
Peerless da25bg08-06
Gradient axp-06 (MCM closeout)
sd215a-88
Thinking the squiggles might have been what dcibel said. Measured it laying on the table, holding it in hand, and holding it tight between the legs, same results. Did get in box measurements today so it's time to start working on the crossover. I'll work up a theoretical crossover with the crossover points I think it needs, then use the minidsp to see if that's close, fine tune again and again, then order some crossover parts. May have messed up in tweeter placement, there's almost a 4db dip centered @2.75k starting @2k, ending @3.4k. Should have used the diffraction calculator before haphazardly placing the tweeter. Fingers crossed it fills in at listening distance.
Question on the mid/woofer handover. Figure the side mounted woofer will cross ~200hz and the sealed midrange rolls off plenty by then, is there any need to create a bandpass for the midrange? Does the bottom of the midrange need rolled off any more or leave it elnatural?
Got a little further on the project. Made plenty of mistakes which pretty much seems to be on par for me. You can see a little black accent around the border ... it's black paint from a paint pen covering up the area Ben123 seeped under the masking tap and onto the stain. Paint is chalk paint w/wax, wood is plain ole lumber yard pine stained with Minwax Red Mahogany and a couple coats of Minwax lacquer. Not that Minwax is the bomb, it's just what the local lumberyard carries ... along with the plain ole pine. Can't tell it in the pics, but the paint has a leather sort of look to it. Happened totally by accident, but in real life it looks pretty neat.
