This will be a build thread for a set of two ways with sub for my nephew Pete. Drivers are the Dayton ES180, RS28F (original) in the SEOS waveguide and a single UM10 in its own box. I'm hoping to have these completed this summer.
Here are a few pics of the cabinet construction just to kick things off.
I really like the threaded inserts for mounting the drivers, but they do require a fair amount of precision installing them. Here's what works for me:
- Align the driver in its cut-out as desired.
- Mark the driver hole locations using a pencil, filling in the circles completely.
- Remove the driver.
- Using a drill bit that is the same size as the resultant circle, align the baffle on the drill press table so the bit exactly matches the circle.
- Clamp the baffle to the table securely.
- Swap the drill bit with the one needed to cut the hole (6 mm in my case).
- Turn on the press and just touch the bit to the board so only the circle is removed, confirming the alignment.
- Drill the hole.
- Turn off the press and vacuum up the dust (you are wearing your respirator, are you not?!!).
- Swap the bit back to the one in step 4 and repeat from there for the next hole.
This is a bit tedious (sorry), but it works for me. Perhaps someone with more skill could skip some steps.
I never water down the glue to seal MDF. That's asking for trouble. I usually use Elmer's white glue. I either rub it in with my fingers or use a brush.
Another builder recently showed a pair of MDF cabs sealed with superglue applied with a razor blade. He's had them 8 months without any edge-creep. Said it took about 2 tubes per cab, and they're about 20 ltrs or so. The glue sets in about 30 seconds, so you have to move fast. I as VERY impressed with the results.
You are giving me serious competition for the slowest builder, but that's a race that I'm happy to lose.
