I have used Loctite polyseamseal in all my recent builds. It is a strong adhesive but still can be removed with some degree of force, plus it'll bond almost anything.
I've mounted similar tweeters sort of like Jason. The flangeless OC25 has a tine lip that can be pressed against a mounting surface. Then you just need to anchor it in from behind.
Bryan, I see that you have the tweeter recessed in from the backside of the baffle. How do you widen such a small hole? I doubt my router can get in there...
Ani, It is a Denovo Audio DW-62S that I purchased from diysoundgroup. It appears they no longer sell them. I had to remove the threaded CD mount and notch the support ribs to accept the rubber bands. I might have a pair you can have(on the house) if you're interested. P.S. They're a perfect fit for the Vifa.
Zaph used a 1-1/8" spade (although I recommend a Forstner), 1/2" chamfer bit on his router, and then rabbeted the backside an appropriate depth. I mounted a 1" flangeless neo tweeter years ago using a similar method.
(Image not to scale)
I am sure BK did something similar. I used a firring strip screwed to backside of baffle to hold the tweeter in place. There are probably fancier means.
Otherwise, Zaph has examples buried on his blog.
https://www.amazon.com/Loctite-1515770-Polyseamseal-All-Purpose-5-5-Ounce/dp/B004XGAR32
Jason, any specifics on how you mounted the tweeter in your Kozo design?
I believe if you purchase a variety of different sized Forstner bits, you will be able to duplicate BK's mounting method.
I wish Vifa made a dome and RR without a faceplate that had a motor equivalent to the XT25G30/60.
