For no other reason than I've had the buyout woofers sitting around doing nothing for years, the tweeters were only $12 each on sale, and I've got more sheets of MDF and crossover parts than I know what to do with. I don't expect these to be super revealing or whatever HIFI term might apply, but they should be quite fun!
The Peerless buyout woofers (835004) were originally $10 each and are a simple surface mount installation. The tweeters (DA25BG08-06) have a standard 4.09" diameter faceplate so they will be flush mounted. No fancy hardwood baffles on these. Probably just some black Duratex over MDF. They won't go super low but they will go super loud - LOL
Drivers just sitting on the baffle board for a photo op.
Very pretty!
I re-read Kornbread's post and realized he was asking about lobing issues, not beaming issues. In that case I know of two other Excel based spreadsheets produced by the FRD Consortium back in the early 2000's: Asymmetrical Response Pattern Estimator (ARPE) and ARPE Lite. Here's an abbreviated description of the programs:
"The Asymmetrical Response Pattern Estimator is a design estimation tool to predict On and Off-Axis Response and Polar Radiation Patterns, in multiple driver systems, from Driver Size/Shape, Inter Driver Spacing/Tilt and Crossover Influences. It is used to see complex driver interactions in Horizontal and Vertical Polar Patterns and in a conical projection, Off-Axis Frequency Response.
ARPE Lite is a slightly simpler version of Asymmetrical Response Pattern Estimator. ARPE Lite produces identical results but is missing buttons to input FRD files, control/display phase, save chart images and is limited to three driver simulations only."
I wouldn't categorize these as "easy-peasy" to use, but Patrick Bateman over at diyaudio created a thread on how to use ARPE. LINK. I would start with ARPE Lite at first.
I could only find these on the wayback machine, so I put both of them in Dropbox:
ARPE: LINK
ARPE Lite: LINK
And the wayback link to the ARPE page with full description: LINK
You can download the programs directly from the wayback page if you want. I use Excel 2010 and it complains about about cell labels in formulas not being supported, but says the programs will still work as Excel will use cell references instead. FWIW.
I need to build some bases/plinth to get the tweeter height up to ear level. Right now I have the woofers wired series/parallel. I'll take some measurements to start playing around with.
I hope to have these ready to demo in Iowa in a few weeks (naked MDF of course).
Oh yeah... and they can get concert level loud!!!!!!
