I haven't seen anyone using the Dayton paper RS drivers lately. I used the original RS150P-8 in my Jonquils project and really like it. So I decided to try the "new and improved" RS150P-8A. The new cones have some sort of shiny treatment compared to the original matte finish. I decided to use a pair of NLA RS28AS tweeters off my shelf. The enclosures have sloped baffles so Z offset between drivers is zero. The enclosures are 3/4" baltic birch ply, with a couple of braces, and pieces of ceramic tile bonded to the inside walls. They are very dead enclosures. Net volume is 9 liters and they are ported out the back. The interior wall are lined with UltraTouch. Here are a couple of pictures:
The removable baffles are just 3/4" MDF with nice rebates and 3/4" roundovers on all four sides. I sealed and sanded them really well then painted them with some rattle can Dupi-color ceramic engine paint (cast coat iron):
Time for a battery of measurements, then XO design.
I like the look, Criag- almost a gunmetal cast grey.
I think I remember them changing the cones maybe two or three (?) years ago Ben. It might have been longer. It was shortly after Rory got out of town.
The paint on the baffles is smooth, no texture at all. I has metal in it so it has that look of being raw cast iron (rough). But it is actually smooth enough I could throw a coat of Mothers car wax on them if I wanted more shine. I like them how they are now and more importantly my wife does too.
One thing about that Dupli-Color engine enamel with ceramic... it stinks to high Heaven when spraying it, so open garage door and window painting only! I sprayed the top plate of my tube preamp with it last winter with the garage heated. The stink snuck into the house and I had to open some windows when it was only in the 20's
How do you measure/sim for the slant without the actual box?
https://www.homedepot.com/b/Lumber-Composites-Boards-Planks-Panels-Wall-Paneling-Acoustic-Wall-Paneling-Sound-Absorbing-Panels/N-5yc1vZ1z18goeZ12l0?NCNI-5&storeSelection=2104,2103,2115,2107,2101
These rolls are a couple of inches thick.
https://www.homedepot.com/p/UltraTouch-R-6-7-Denim-Insulation-Roll-16-in-x-48-in-6-Pack-60306-16482/202710055
These products can be cut with a good scissors and I use double stick carpet tape to fasten it to the sides of the cabinets.
It seems to be stuck somewhere in IL. Not sure if there are still disruptions or not, Minneapolis seems to be calm the last few days.
