Hi guys. It's that time of year again when it's getting colder outside and my DIY interests shift towards vacuum tubes...
I definitely don't need another tube amp. Actually I don't really need another tube preamp, but they are fairly cheap and LOTS of fun to build.
A couple of years ago when I was at DIY S. Dakota I bought some old tube stuff off the swap meet table from Mike Jennings for only $5. Turns out I got a very nice power transformer, a pair of cool vintage smoked glass 6V6GT tubes, a multi-section high voltage cap, and a decent 5Y3 rectifier tube.
Over at diyaudio.com there is an epic 6V6GT line preamp thread from a guy named Salas. I have all the parts to build this design, sans the miada regulators. That doesn't bother me at all. I like to keep tube circuits as simple as possible and feel they sound just fine or better that way. So my power supply will be more my design. Otherwise the basic circuit is his design.
I will post a butt load of build pictures here along the way. I bought a nice hickory board today that has a ton of grain!!! That board and a piece of 0.0625" aluminum plate I have will form the case.
More to follow Gents.
The great thing about many tube projects (like this one) is how simple the circuits are with only a few resistors and maybe a capacitor or two per channel. Honestly they are no harder to construct than a 3 way passive speaker crossover. That said, they do involve high voltage, high enough to kill you. So proper fusing, grounding, and basic common sense are manditory.
I plan on designing my layout this weekend and will post those drawings. This preamp could be build very compact, but because this is DIY (no commercial restrictions) I will build it jist as large as I need to. That will allow me to keep very generous spacing between the noise generating power supply parts and the very sensitive small signal audio components.
https://www.tubedepot.com/products/tung-sol-6v6gt-new-production-power-vacuum-tube
Electro-Harmonix
Genalex-Gold Lion
JJ Electronics
Tung-Sol
Mullard
Telefunken Black Diamond
These range from $14 - $40 each.
Then there are NOS (New Original Stock) tubes like RCA, Sylvania, Bendix, National Union which range from $60 - $250 each!
But this circuit is only optimized for 6V6 tubes. Other tubes like the 6L6, EL34, etc. have the same octal base and may work in this preamp, however, the circuit values are not optimized for their tube curves.
It didn't come with a stand, and since my work shop is my garage and driveway I built an over sized base out of left over 2x4's and plywood. I bought some nice swivle casters with brakes.
A couple years later a guy at work sold me that cast iron router table for $75. I had to drill new holes but it lines up perfectly and gives me even more table top area.
A couple years ago I so sick and tired of the wimpy Craftsman fence. I found a floor model Sawstop fence at Woodcraft and got it for half price.
I keep the top clean and waxed and the saw alignment is dead nuts. It is soooo much more fun to cut panels with a saw that has a perfectly parallel fence.
I wonder what that's like.
Calculated Industries 7434 AccuMASTER 2-in 1 Magnetic Digital Level and Angle Finder / Inclinometer / Bevel Gauge, Latest MEMs Technology, Certified IP54 Dust and Water Resistant https://www.amazon.com/dp/B0148M7P4O/ref=cm_sw_r_cp_apa_62zbAbK0V3NQY
You put it on the tabletop of your tablesaw or miter saw and "zero" it. Then put it on your blade and set it to whatever angle you want. You would be surprised how many times your off by 1 deg.
Just some random tips but if you cut a 45 cut one edge on the left of the blade and the other on the right side it should always add up to 90 again even if your off.
The trouble with compound miter saws is that they always have flex when they are fully extended out. You can pull it outward all the way and apply sligjt pressure in either left or right direction and watch it deflect a little. I try to start the saw in the fully inward position and when you extend it outward try to use a soft touch so you dont apply pressure to one side and proceed with the cut.
